Title says it. Basically: how to turn concave areas into convex ones, and vice versa?
Any ideas of how to achieve this?
Turning a mesh inside out... like a sock!?
2770 4 1-
- albinioni
- 71 posts
- Drasko Ivezic
- 109 posts
- jsmack
- 8177 posts
Spherical inversion is one way. You can do it with a similar method to stereographic projection.
https://en.wikipedia.org/wiki/Inversion_in_a_sphere [en.wikipedia.org]
- albinioni
- 71 posts
Interesting, thank you!
Looks like it involves some quite complex math.
If its a shape with a clear volumetric center with equal distance to any point on the mesh surface, like a sphere, I was thinking if it would be possible to perhaps "mold" the inside of the mesh using some kind of boolean operation, and then apply a displacement attribute depending on the distance to the center. But I'll have to try.
Edited by albinioni - April 24, 2021 13:42:23
- Librarian
- 142 posts
@albinioni
I posted here files with Spherical inversion and other stuff, complex shapes and MATH ,that you can find also if you google MATH BERLIN HOUDINI. " vex codes"
https://forums.odforce.net/topic/44999-on-growth-and-form/?page=8 [forums.odforce.net]
