Usage Statistics, custom HDAs (way to best Parm Interface?)
   1475   1   1
I have a task ahead of me to create 70-100 HDAs, that should together create a toolset.
I will work on it for about a year or two.
One of the biggest challenges for me will be creating a suitable Parm Interface.
I was wondering if the Usage Statistics could be used. I would approach it like this:
- Use the toolset with unlocked HDAs (just me as a developer)
- Edit the parameters inside the HDAs to achieve desired results
- Track (several months) which parameters were most often changed
(possibly the range of values too)
- According to that, promote the most frequently used parameters
- Release the toolset
Is there such a system built in Houdini? Is it accessible for us? I am referring to this:
Usage information for different Houdini node types
https://www.sidefx.com/legal/houdini-anonymous-usage-statistics/ [www.sidefx.com]
Edited by ikoon - May 5, 2021 07:50:49
I could also develop my custom statistics:
- check which parms are not isAtDefault()
- or add an event callback to the parms (hou.nodeEventType.ParmTupleChanged)
- write to a file, after each successful usecase of the HDA (probably manually with a button)
- collect and evaluate those files after few months
I am facing such a big challenge for the first time.
I don't feel like all those usecases will fit into my head :S
