setting Python relative reference
   2879   3   1
So im back into python and come across 1 problem i can't figure out.
so what i want to do is get the selected arnoldImage node and set that to another usdUvTexture node.
All work fine if you run it once.
so the relative path is set automaticly and in the usdUvTexture node in the file i get `chs("../ARN_new/BaseColor/filename")`
wich is correct as it is the relative path to the arnoldImage node
but as soon as i run it another time to update it so it should put `chs("../ARN_new/Roughness/filename")` in the node it doesnt work.
As it automatically fills in the ref and instead of updating the usdUvTexture node it fills it in the arnoldImage.
is there any way to solve this
import sys
import toolutils
import hou
##make selection
selectedNode = hou.selectedNodes()[0]
selectedNodeName = str(selectedNode)
nodeType = hou.nodeType(selectedNode.path())
##get parent name and contex path (Arnold material Builder)
arnoldMatBuilder = selectedNode.parent()
arnoldMatBuilderConnection = arnoldMatBuilder.outputs()
arnoldMatBuilderPath = arnoldMatBuilder.parent().path()
arnoldMatBuilderName = str(arnoldMatBuilder)
amb = hou.node(arnoldMatBuilderPath)
texRef = str('`chs("../'+ arnoldMatBuilderName + '/' + selectedNodeName + '/filename")`')
usd_tex_base = hou.node(arnoldMatBuilderPath + '/' + "USD_tex_BaseColor_" + (arnoldMatBuilderName[4:]))
usd_tex_base.parm('file').set(texRef)
Maybe you need to use setExpression() instead of set()?
https://www.sidefx.com/docs/houdini/hom/hou/Parm.html [www.sidefx.com]
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
I tried than unfortunately that didn't work.
Or at least it sets the expression correct but also adds a key frame or some sort. (the .parm becomes green in the node)
So the relative reference doesn't work then.
So if people have a solution for this that would be perfect to
Ok it's a bit of an ugly solution and if anyone has a proper i would really like to know.
But for now i gist set .revertToDefaults() and then rund the part to set relative ref again.
This works for now
Cheers
Robert
