Reverting overrides on instances
   2219   1   1
Hi. I'm making a tool that uses alot of instancing to assemble a level in Unity. I've come up against some issues with the way Houdini engine overrides lots of properties on each instance that you may not want. You can control a few overrides via the Unity attributes [www.sidefx.com] but lots of other attributes will also be overridden. Instead I found it better to revert all the overrides that occur with the instancing so that each prefab can be set correctly upfront. To do this I attach a script via the Unity script attribute [www.sidefx.com] which looks a bit like this:
    private void GetInstancedOverrides()
        InstancedObjs.Clear();
        foreach (var childTransform in GetComponentsInChildren<Transform>())
            if (childTransform.gameObject.name.Contains("Instance"))
                InstancedObjs.Add(childTransform);
        FixedInstancedOverrides();
    private void FixedInstancedOverrides()
        foreach (var childTransform in InstancedObjs)
#if UNITY_EDITOR
            PrefabUtility.RevertPrefabInstance(childTransform.gameObject, InteractionMode.UserAction);
#endif
        Debug.Log("Fixup fired");
The issue is this fires to early and breaks rebuilds or recooking of the HDA. i used editor coroutines to delay running these functions which does work but I wanted to ask if there was a good way to latch onto the event of the HDA to say the cook or rebuild had finished?
Sounds like there might be a bug somewhere here. Can you file a bug report with an example HDA to make sure? https://www.sidefx.com/forum/topic/38188/ [www.sidefx.com]
