Heightfield Slump doesn't seem to work
   2631   1   0
Im trying to use slump node in houdini 18.5
Put in a default heightfield and add default noise
it creates flow channels but height is unchanged.
I set to granular with same result.
press in do erosion and get an invalid volume "temp_debris" error
I tried three different workstations with same result how is this node supposed to used?
the erosion still doesn't work but realized since slump requires a mask to be present
