KineFX mocap cleanup
   3130   2   0
Is there any resource on how to cleanup mocap data with Kinefx (without doing it manually)? Stabilise joint node seems to be the right place to start, but I found documentation is not really informative. Anyone has some resources or tutorials they could share?
Here is one I got a lot out of. This converts mocap data to simultaneous onion-skin style line rigs. Because each frame is made up of lines, you could use standard SOP tools to smooth or adjust them.
https://www.sidefx.com/tutorials/retarget-the-cmu-motion-capture-database/ [www.sidefx.com]
Edited by Enivob - June 24, 2021 13:45:39
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Thank you, will look this up!!!
