I have 80 variations of my geo. each one 48 frames of animation
i want to make a montage for every 4 variations and end up with 20 videos, instead of one huge video with all 80 variations animating. how can i partition my data so that i get that result?
The screenshot i have attached is what i don't want, which is all my variations animating in one montage sheet.
Create multiple video montages
2225 3 1-
- papsphilip
- 388 posts
- papsphilip
- 388 posts
- bhfx
- 3 posts
- papsphilip
- 388 posts
this was the code i used inside the python processor
import os
import pdg
import re
for upstream_item in upstream_items:
new_item = item_holder.addWorkItem(parent=upstream_item)
#print(new_item.expectedInputResultData)
#get filepath
filepath = new_item.expectedInputResultData
#print(filepath)
#get filename
filename = filepath.rsplit('/',1)
if(filename.find('-')!=-1):
#get sequence number
pattern = "\-(.*?)\."
num = re.search(pattern, filename).group(1)
#get frame number
split_name = filename.split("-") #we split the filename on the dash
frame = split_name
#calculate new frame number for merged sequences
nframe = str(int(frame)+(int(num)*48)) # 48 is the total number of frames for each sequence
nfilepath = filepath.rsplit('/',1) + '/' + nframe + ".png"
os.rename(filepath,nfilepath)
and here are some screenshots of my setup. sorry its not a file but it will take a while to make a demo scene
import os
import pdg
import re
#get filepath
#print(filepath)
#get filename
#get frame number
frame = split_name
