I have two rbd packed object connect to rigidbody solver
And i want to assign dop sop solver to first object.
how to assign dop sop solver for each objects?
How to assign dop sop solver to each objects?
3526 5 2-
- Jisung
- 14 posts
- Enivob
- 2658 posts
I think you can extend the Dataname to specify elements from the data. In your case, with only two objects, the ids will be 0 and 1. So to exclusively reference id #1 in the SOP Solver your dataname would need to be Geometry:1
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- Jisung
- 14 posts
EnivobCan you explain more easily? I`m honestly don`t know modify dop network elements so, it`s too hard for me
I can`t find tutorial for how dop network data is working and modifying
Too hard for me please help me
I`m including this test file and i want to apply that sop solver to only rbdpackedobject1 I still don`t know how to assign only this object
Edited by Jisung - July 5, 2021 14:17:09
- cwhite
- 802 posts
- Jisung
- 14 posts
- maoyaozhuayu
- 1 posts
cwhite
You can use an Enable Solver with the Enable Objects parameter set to the name of the object you want to enable its input solvers for (in this case, you'd wire your SOP solver into the Enable Solver)
This problem has troubled me for a long time, and now it can be perfectly solved. Thank you, my hero. Thanks from 2023.
