Im following a tutorial of Gnomon Workshop, im stuck in a step where it uses a curve plugged in to a sweep node while using the outer edge of a grid as the backbone but it seems like they are using an older houdini version, so the sweep node is completely different. So the sweep isnt working properly, it is sweeping the curve along the edge of the grid but its only working properly at the corners. I attach some screenshots below:
Help with a sweep node problem
2989 1 0-
- swg369
- 2 posts
Hey guys,
- Viktors_A
- 7 posts
