Is there a way to edit(translate or rotate) a geo in Solaris, using the original pivot point position that was assigned to it?
In my case, I'm exporting my model from Maya as an USD file with a certain specific pivot point. (The pivot points seems to be retained if I were to open it again in Maya)
I also noticed that the attribute of the pivot does get carried over in Solaris under the xformOp:Translate:pivot attribute. But if we were to move the object using the edit lop, we seem to only have two choices where the pivot is either at the origin, or at the center of the geo.
Would appreciate some advice, thanks.
Retaining Pivot points from a Maya exported USD file
7116 8 1-
- FoamFX
- 10 posts
- AndreasWeidman
- 129 posts
- FoamFX
- 10 posts
Hello Andreas,
Thanks for taking the time to reply.
I just tried with the transform node, and it's the same as well, the pivot doesn't match.
If I were to manually insert the values from the geo's xformOp:Translate:pivot attribute, to the Transform(or edit) node's Pivot Transform, then the pivot snaps to the correct place.
I assume that perhaps it's possible to create a relative reference that points the pivot transform value to an USD attribute?
- jsmack
- 8181 posts
- AndreasWeidman
- 129 posts
FoamFX
Hello Andreas,.
Seems like this should be the default behavior? Perhaps someone from staff can shed some light on this. Otherwise, try filing it as a bug or feature rewquest.
- FoamFX
- 10 posts
- goldleaf
- 4265 posts
FWIW, I tend to recommend using an xform primitive to preserve a pivot/transform location, rather than an xformOp. The
If the pivot is instead a real xform prim, it's a more concrete thing tools can simply transform.
pivotxformOps are useful/interesting, but pretty much only if every tool is only reading/writing xforms in that pattern. Whenever there are additional transforms added to a primitive, the pivot and its inverse don't make as much sense any more as "the" pivot; they're just another xformOp applied. You end up needed much more tooling to preserve pivots.If the pivot is instead a real xform prim, it's a more concrete thing tools can simply transform.
I'm o.d.d.
- FoamFX
- 10 posts
Hello Goldleaf,
Thanks for the suggestion, just tried out using an xform prim as pivot method, (basically creating a group in maya with the position as the desired pivot) and I think this is a great solution, and the one I shall be implementing. Definitely appreciate the help, thanks!
Edited by FoamFX - Aug. 2, 2021 09:53:57
- wlvl_r
- 15 posts
I have a related issue,
I'm exporting my geometry from Maya as an USD file. The geometry is made of few primitives with specific pivot points ( a few boxes with pivot at one of the corner )
I want to process( ie polyreduce ) and export the geometry as USD from Houdini retaining the original pivots.
Any directions would be appreaciated!
1 - In the scene graph details I cannot see the "xformOp:Translate:pivot" attribute as FoamFX is.
But if I reload the same USD in Maya the pivots exist and are correct.
2 - In USD ROP Lop (usd_rop) I cannot find any option regarding the pivot. Am I missing it? Is there a special attribute that I can use to override it ?
