EP curve in Houdini
   1532   2   0
Hello everyone, here is a simple question. I have some points in Houdini and I want to make a NURBS curve. There are two types of NURBS curves. One is EP curve(curve through every point), the other is CV curve(every point is a control point).
I use a add node to connect every point as a polyline and use a convert node to turn it into a NURBS curve. But I can only turn it into a CV curve. So how can I turn it into EP curve, which every point is on the curve and not as a control point?
Thanks in advance!
if you want to get the same result as Curve SOP set to Breakpoints
use Fit SOP, Method Interpolation and in Interpolation tab set scope to Breakpoints and U Data Parameter to Uniform
Thank you very much! The information is really useful.Have a good day.
