"_" in filenames
   2018   4   2
I have this channel expression:
$HIP/Render/$OS`chs("../../null1/shot")`.exr
which sets the name of a saved output. Now let's say `chs("../../null1/shot")` is 1 and $OS is "file". In this form, it works as expected and Houdini resolves the name as file1.exr
If I edit the path to:
$HIP/Render/$OS_`chs("../../null1/shot")`.exr
Houdini resolves the name as 1.exr instead of file_1.exr.
Is there a way to incorporate an underscore in a filename referencing the value of another parameter?
Ivan
Yep, that appears to be a bug.
What does work is the dash character. Try that instead.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
be sure to enclose variables with `` as well to avoid this kind of problems.
In your case Houdini try to resolve the non existing variable "$OS_" ....
Andr
And to avoid this ambiguity you can use {} to hint where your variable name is ending
So in your case ${OS}
Thanks guys! ${OS} solved the issue.
Ivan
