AMD Ryzen Cooling
10704 20 4-
- maxpayne
- 40 posts
Hi everyone. I'm. sure that someone here has Ryzen latest gen. I was wondering what type of cooling do you use. Either Air or Water ? I'm sure cpu will heat a lot during the sims or render so I was wondering if Air cooler will be enough. I'm a bit sceptical about water cooling for the reason of reliability but I'm not sure Air will give enough performance to keep cpu cool. I got Ryzen9 x5950
- MilanB
- 161 posts
- maxpayne
- 40 posts
- anon_user_09389530
- 205 posts
Hi, I tested my 5950x in a battle of heavy water sims, works fine and I'm happy with it.
I use this all in one CPU water cooler: https://www.arctic.de/en/Liquid-Freezer-II-360/ACFRE00068A [www.arctic.de]
The motherboard: Asus PRIME X570-PRO
Edited by anon_user_09389530 - Sept. 20, 2021 01:07:42
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
- citizen
- 113 posts
maxpayne
AIOs have such a low failure rate, that it's not even worth mentioning.
The CPU clocks down when the max temp is reached (limit set by AMD), so the better the cooling solution, the more the CPU will be able to stay at the highest clock speed possible based on your BIOS settings (OC / no OC).
I'm on a Ryzen 9 5950X with Cooling Liquid Freezer II - 420, Asus Dark Hero X570
I get 30k in Cinebench R23.
- eschwab
- 63 posts
- GCharb
- 290 posts
Running a 5950x with an ARCTIC COOLING Liquid Freezer II 280mm in a Fractal Design Define 7 Compact silent case, I set it up for 70c max, works really well even on full load, I went the liquid way because I wanted a silent workstation, and mine is pretty much silent, I only hear a buzz on full load!
Edited by GCharb - Sept. 24, 2021 10:21:20
- sekow
- 244 posts
- maxpayne
- 40 posts
I was wondering about Noctua air coolers since they have good reputation but eventually went with water corsair icue 280 pro. Temp. never got higher than 65 yet. Tried gaming and short sims but I believe after a few hours of sims or rendering it will be much warmer. Will see.
Edited by maxpayne - Sept. 26, 2021 13:50:10
- MilanB
- 161 posts
- maxpayne
- 40 posts
- GCharb
- 290 posts
Tower coolers like the Noctua will last forever, while AIO water coolers usually fail after 7–8 years, but they keep things way cooler from my experience and produce much less noise, a custom water loop with a separate pump is also a good solution, since the pump is what usually fails, in a custom loop the pump can easily be replaced; also, a custom loop usually keeps things even cooler than an AIO water cooler!
Edited by GCharb - Sept. 27, 2021 09:48:31
- citizen
- 113 posts
GCharb
But you're leaving a lot of performance on the table that way. There's no point in limiting like this, not even if you were to keep it for 10 yrs. I have another system with an old i7 cpu and keep it heavily OC from day 1 and it's still alive and kicking.
Given that most of us in the 3d/ gaming/ other enthusiast domain, upgrade every few years, squeezing every last drop of performance makes the most sense.
This particular cpu of mine on the MB that I have scores around 25k in Cinebench R23 at default settings. If I overclock it (using "dynamic OC switcher" to not lose the PBO boosting, a feature only Asus Dark Hero has) I get 30k+ in Cb-R23. That's a whopping 20% performance increase!
Up to each of us, of course, I'm just saying...
- GCharb
- 290 posts
- citizen
- 113 posts
- GCharb
- 290 posts
- citizen
- 113 posts
- GCharb
- 290 posts
citizenI just setup my bios with your settings, I can hear the fans on idle, but it's not too bad, will test on full load later on, thanks for sharing!
My CPU fans' curve looks like this: 40°C - 20% RPM; 70°C - 60% RPM; 90°C - 100% RPM and it's very silent. I can hear the fans ramp up if I bow down to the case, otherwise, since I'm always listening to something in my headphones it makes no difference.
EDIT: I just ran Prime95 for 30 minutes, temp got to 90C, as expected, and as low as 27C when idle, which is pretty decent, and noise level was acceptable, I'll keep that setup for the time being, thanks again!
Edited by GCharb - Sept. 29, 2021 12:57:52
- ikoon
- 231 posts
citizen
Thank you for sharing this. Very nice results! Single core is also better with OC? (Can you post result please?) Have you seen same results with the same hw, or you got a "lucky" chip?
I am waiting for the Intel 12900K, and then I have to decide, so any info is really valuable.
- omercf
- 2 posts
Hello, I wanted to share my experience.
I'm using a Ryzen 9 5900x on a B550 Tomahawk MAG motherboard.
CPU is being cooled by an ARCTIC Freezer 34 eSports DUO air cooler.
My case is mid-tower with 2x140mm Arctic F14 intakes at the front and 1x120mm Arctic F12 exhaust at the rear.
I have an RTX 3080 in the system.
My max temps are 80 degrees Celsius on CPU and 70 on GPU; idle temps are 45 and 48 degrees respectively.
Fan RPM is limited to 70% to %75 on all fans up until these max temps.
I set the fans to go faster if any of these temps rise above 80 degrees. But they almost never do.
When idle, intake fans run at 20% RPM, exhaust runs at 25% RPM and CPU coolers run at 30% RPM. GPU fans stop completely.
This setup is utterly silent when idling and very quiet under max load.
I literally don't hear anything while turning on or while idling.
While rendering I tend to take a nap on my office couch. I have to look at the screen to tell if the operation is still going.
The case is not a silent padded case. It's a regular airflow case with mesh paneling. Nothing fancy.
I'm also using an old 750W Bronze rated PSU. I replaced its 140mm fan with the same Arctic F14 intake fans so I could PWM control the PSU fan to run silent.
Hope this was helpful.
