Rename prim paths possible in LOPS?
   7295   3   3
Is it possible to rename prim paths on a referenced USDA file in LOPS?
What we're trying to do is to layer a USD hierarchy on top of another, however the naming in each hierarchy is slightly different.
We're hoping to be able to do this in somewhat of a procedural way, as we have a lot of files, with basic name changes such as:
rockA, rockB, rockC.
If you see the attached image, we're trying to reuse a part of the A hierarchy and overlay it over B, by renaming the A paths to B.
Is this possible? Or is there another way to achieve this result?
Thanks for your time!
Klaus
Screenshot 2021-09-20 195945.jpg (42.8 KB)
Hi there,
I was struggling with this the other day, too. I'm all new to LOPs so without better knowing I used a stage manager node. I'm also interested in a more procedural way.
Good luck.
kskovbo
It's not possible without flattening the stage and using SDF Copy Spec (stage manger does this.) It's best to build the correct hierarchy to begin with.
@kskovbo I think you're looking for Restructure Scene Graph LOP [www.sidefx.com].
For example, this:
Becomes this:
Restructure Scene Graph LOP has a few other options:
Edited by AnimGraphLab - May 14, 2023 04:51:58
Generalist. Transforming still images to 3D animation 🔮
Socials: https://linktr.ee/AnimGraphLab [linktr.ee]
