Baking aerodynamic map in Houdini
   2061   3   1
Hello I wrote water on surfaces simulation some time ago.
Code need refactor but more i need tool to bake something i called aerodynamic map (pretty similar to normal map) that i made by hand for now.
My plan was to make tool with Houdini Engine that bake aerodynamic data from for example 8 directions. I need some general directions what topics I should looking for. Any advice would ba appreciated.
Hi Gand,
the VDB potential flow node might be interesting.
flow_map_2.hiplc (79.2 KB)
Konstantin Magnus
Hi Gand,
That's great. Exactly what i need. Thank you very much.
Edited by BGadz - Sept. 28, 2021 18:14:12
Konstantin Magnus
Hi Gand,
I tried to use this node few weeks ago as I wanted to advect my colors with it and need to be relative to the curvature.
I don't understand how to. How to feed an additional velocity to the node , which required a VDB surf, my vel is usually carried with a volume... Merge both before doesn't work
Im not familiar with that yet, if some of you might share their experience or a simple example, will be appreciated
Cheers
Edited by vinyvince - Nov. 27, 2021 16:56:12
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
