Vex syntax getting Point Position
   13803   2   1
I have a line with a couple of points. In a point wrangle I try to access the position P.y of point 0 .
When I use vector as type I can extract the position.
vector master_pos = point(0, "P",0);
But when I try to just access the position in y it fails and returns just 0.
float master_pos = point(0, "P.y",0);
What do I miss?
That's because P.y doesn't exist as an attribute and defaults to zero.
Try this instead.
// VEX: Fetch the Y component of point #3.
vector master_pos = point(0, "P",3);
float temp_y = master_pos.y;
What is interesting is that hScript supports the fetching of individual vector components, but VEX does not. Here is the equivalent using hScript.
// hScript: Fetch the Y component of point #3.
point("/obj/geo1/OUT_MESH", 3, "P", 1)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Casting to vector, then it works.
float master_pos = vector(point(0, "P",0)).y;
