Exposing transform edit handle into HDA
   1631   0   0
Hey All,
I'm curious if there's a way to expose the handle of an Edit (or any transform) into an HDA. So that when a user selects the points created, and hits "Enter" or "T" the transform will be placed inside of the defined edit node, and not create a new one.
What I'm attempting to do, is allow a user to select a point that is created inside of the HDA, and then query this point's position to be used inside of the HDA.
I've attached a simple HDA which just has an Add and Edit nodes.
Any help would be appreciated.
testTransform.hdalc (4.2 KB)
