Issue with Karma CPU renderer.....black frames
   4836   3   0
I am trying to render a basic bonfile from the shelf tools and numerous frames come out black?! They appear to be empty frames?! (the actual bonefine starts at frame 60 but this is after that .... sometimes several frames in a row.) This of course causes flickering when I attempt to play it. I am using Karma on CPU on the 455 build. I tried even switching disks as the original disk I was rendering to occasionally disconnects but that made no difference. I know it rendered correctly on 383. One other note...when I open this file I see an error about attributes (don't have it in front of me.)....I tried replacing the node to see if that would make a difference but it doesn't seem to. Thoughts? I'm going to try using a different render engine as soon as I get a chance.
Try kicking out an MPlay viewport render. That would be a quick test.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Enivob
Tried it...same result...flickering. Wonder if it's a bug in 455? I rendered it originally in 383 with no issue.
Any news on this? I am having the exact same issue with the .622 build.
Billowing smoke shelf tool renders every few frames black.
In the Karma viewport, rendering to Mplay and to disk, all the same.
Edit:
I think I found what this issue is related to. When I run a simulation with mem cache on and the render with Karma I get a black frame every now and then. However, if I turn off mem cache and render the sim directly (simming every frame at render time) then all is fine.
Tested in .589, .622 and .655.
Edited by OneBigTree - June 22, 2022 14:57:14
