disable keys
   2654   4   1
How does one disable keys in the Animation Editor ?
When I select some keys in dopesheet view, RMB select "Disable Keys", the keys are greyed out, but this has no effect whatsoever on the animation.
Is it broken, or am I doing something wrong ?
Thanks.
seems to work for me, just make sure that the whole segment between keys turns black also
then such black segments between the keys will hold the first value coming in, ignoring the keys within the segments
Edited by tamte - Jan. 31, 2022 14:16:22
Ah, great thanks.
So you have to select the keys you don't want deactivated as well.
Why not do that automagically by design, or rename it to "disable animation range" or something like that ?? When you select keys and deactivate them, you expect to actually deactivate the selected keys and not a range.
Not very intuitive omho :-/
Edited by toonafish - Jan. 31, 2022 14:32:53
toonafish
essentially you are enabling/disabling frames/frame ranges, they don't even have to be full segments between keyframes
toonafish
feel free to submit RFE
I personally find Animation Editor quite buggy and full of surprises
like if you have disabled keys deal with snapshots your disabled keys will be enabled
Edited by tamte - Jan. 31, 2022 14:51:21
like if you have disabled keys deal with snapshots your disabled keys will be enabled.
Hey, Houdini is full of surprises, but that’s why it’s called Houdini I suppose ;-)
RFE, maybe I’ll do just that.
Thanks.
Edited by toonafish - Jan. 31, 2022 16:00:17
