This feels like such a despicable noob question, but i'm wondering what's the easiest way to access attributes on 2nd Input Geo in a attribute wrangle.
So, let's use a simple example of a single point coming into the 2nd input of my attribute wrangle. With a grid of points in the first input.
If I was using a point cloud to search for points on that grid I would want to write:
int points = pcfind(0, "P", v@pos, @ptnum);
However, this doesn't give the desired outcome. The correct working line in this case would be to just explicitly state the point number (0 in the case of a single point):
However, if the geo is any more complicated, I wouldn't want to manually input point numbers.
Is there a better way to access the point numbers on incoming geometry. Say I wanted maybe access any point(s) that is in a certain group or that has a certain attribute value in that geo coming in the 2nd input. How would I properly reference all/any of the points on the incoming geo on the 2nd input. My understanding is that @ptnum is designated for just the geo in the first input ).
Thanks in advance for any advice/explanation anyone can provide.
