Material X random node?
2451 1 0-
- lloydwood
- 107 posts
I'm creating a material X shader and have come up against a bit of a roadblock. I need to be able to generate a random value with the output of from a material X node as the seed. I figured I'd just use the random material X node but there doesn't seem to be one. Ok, I thought, I'll use a VEX snippet but you can't do that either. So now I'm stuck and looking at having to do it as a standard Houdini material. Before I do, is there a way around this?
- mark
- 2675 posts
