Select by Curve ForEach Loop Question Houdini 19
3221 4 0-
- madguru
- 100 posts
I am trying to create a setup that selects points based on proximity to point groups on curves. I think I have most of it put together, except the group names being applied within the foreach loop on the delete_other_groups and group_create nodes.
Desired output is the grid mesh, with point groups with the same names as the source curve point groups.
Thank you,
Adnan Hussain
Thank you,
Adnan Hussain
- CYTE
- 803 posts
- madguru
- 100 posts
- tamte
- 9406 posts
usually there is no need for groups, you can use name attribtue and easily transfer it from closest surface using Ray SOP
no need for foreach also
but if needed you can create name from groups and groups back from name after the transfer
Edited by tamte - Feb. 21, 2022 00:55:58
- madguru
- 100 posts
