Hello magicians. Here I have a scene with a glass object and inside my animation. The problem is the following, no matter how thick the glass is with karma I always have a big deformation. Whereas with mantra not. And so it's annoying for my rendering.
How do I do so that under karma the glass reacts the same way as under mantra ?
is more a problem with how karma see the glass like an object full of glass
to a problem on ior
if you want i can put the scène on my server
Thanks for your help
Glass shader without deformation in karma ?
3890 4 1-
- bgood
- 142 posts
- tamte
- 9380 posts
if your glass has true thickness this should work fine as long as the thickness is thicker than Ray Bias
alternatively you can use single sided geo and use PBR Glass shader, just check
- Thin Film refractions: on
- Shade Both Sides as Front: on
(in case you are using XPU, Standard Surface MtlX also has Thin Walled checkbox and it seems to be working fine in XPU, but in CPU mode it seems to be broken)
bgoodno need to share your production scene, just make a simple example if its still not working
Edited by tamte - Feb. 19, 2022 15:02:37
- bgood
- 142 posts
- tamte
- 9380 posts
bgoodas I said may depend on your ray bias
i have a thickness on my mesh thats work on mantra not in karma.
bgoodno, it's a shader setting
thin film refraction on is on karma settings no ?
maybe you can use Classic Shader, which has Thin Film Refraction as a single checkbok and also wraps Fake Caustics inside so you wouldnt have to do it yourself, essentially it uses PBR Glass inside
(Principled Does too, they just didnt promote that setting)
- bgood
- 142 posts
