Hello, I'm experimenting with kinefx rig and I need some help about rig controls. I created some controls for the main parts of an arm, elbow, wrist, etc. using attachjointgeo sop.
My question is, how do I select these controls ? Documentation says to select them using rig pose but they are not selectable at all, I can select only the points (joints).
Another method is to create an HDA and promote the controls using the string "kinefx__rigpose" as default state in the HDA node tab, but it returns an error "kinefx__rigpose failed to bind handle 'motionpath_handle'.kinefx__rigpose failed to bind handle".
How can I use the controls (in sop or at obj level?) Anyone can help ?
Thank you
Ray
kinefx rig controls: how to use them ?
3249 1 2-
- madrenderman
- 129 posts
- madrenderman
- 129 posts
I finally solved the mistery ? In the fur dude tutorial page https://www.sidefx.com/tutorials/kinefx-rigging-fur-dude/ [www.sidefx.com] someone commented that controls shape must be polygons otherwise they are not selectable, so I converted them from nurbs to poly and now they're finally selectable.
