I know you can get uv space to world space, but is there a way to trace backwards?
if I have vector3 position on the model surface I want to find out where is it in the UV coord?
houdini from model world position to uv position?
3233 4 1-
- JIn_
- 20 posts
- tamte
- 9374 posts
you can use Ray SOP in Minimum Distance mode and import uv attribute
or you can use xyzdist() followed by primuv() VEX functions to get coordinates on the closest surface and interpolate uv attribute at that location, essentially the same as Ray SOP above does
Edited by tamte - March 14, 2022 23:16:21
- animatrix_
- 5091 posts
Here is an example:
Lookup UV :
Here is an example:
Lookup UV :
int hitprim = -1; vector hituv = 0; xyzdist ( 1, @P, hitprim, hituv ); i@hitprim = hitprim; v@hituv = hituv; vector p = primuv ( 2, "P", hitprim, hituv ); @P = p;
- JIn_
- 20 posts
- JIn_
- 20 posts
