How to use Stash SOP to "inject" geometry into an asset?
   1951   2   0
From Stash SOP [www.sidefx.com]:
You can link the geometry parameter to a parameter on a parent asset. This allows assets to inject geometry into a network without making the contents editable.
What does it really mean? Stash SOP's interface looks like this:
How could I inject geometry to it? Just link to its input? So is it any different from, uh, just linking to an asset's input?
Screenshot 2022-04-06 221912.png (18.1 KB)
The geometry is stored in the parameter called Geometry Stash in your screenshot
You can promote it to your HDA (also it's common to make it invisible)
And then store geometry in there using Python with parm.set(geo) for example
tamte
Thank you. I didn't realize that "Geometry Stash" is a parameter itself.
