How do you apply xform attribute info from oriented bounding
   5135   3   2
When you use an oriented bounding box and create the xform detail attribute, how do you apply that info to another object to match its rotation? I assume this is basic matrix transforms, but I'm still getting up to speed on those guys.
You can use attribute copy to copy the detail xform attribute over to a different object then use the node "Transform By Attribute" to apply the transform
That did it, thanks! (Turning off the Match P and copy local variable required a bit of clicking to figure out, but with your help I triumphed.)
bentway23
shouldn't be required, just type xform instead of Cd into the Attribtue name
(since Match P doesn't matter if you are not copying P
and Coly Local Variable doesn't matter since even if you had some and they were copied it wouldn't affect what you are doing )
