Hi folks,
Is there a way to resample a curve precisely? Nor resample or the progressive resample resamples the curve with exact segment length.
Precise segment length resampling
1955 2 0-
- szmatefy
- 141 posts
- Fenolis
- 152 posts
On the Resample SOP you can disable "Even Last Segment Same Length", this will give you segments of the specified length. If your original curve's length is not an integer multiple of the specified length, this will cut off the last point. If you want to keep the last point (last edge is shorter than specified length), then also enable "Maintain Last Vertex".
- szmatefy
- 141 posts
