Issue with exporting KineFX animation
   3866   2   1
I followed a Houdini tutorial: https://www.youtube.com/watch?v=3_NRGjq7RsU&list=PLXNFA1EysfYn0XZtZ6TqI4Xwi3_mgdUc2 [www.youtube.com]
But I have trouble exporting it. I'm not sure where the problem is coming from but here is my export:
And here is one of the problem i'm facing (when I had a name):
Also, at this point my rop_fbxcharacteroutput does export something but not right and the rop_fbxanimoutput export an empty file.
Here is my Houdini file:
Thanks in advance if anyone can find what is the problem.
Have a good day.
Edited by Aschdox - May 2, 2022 04:46:44
animation_rabbit.hipnc (3.0 MB)
Capture d’écran 2022-04-29 113336.jpg (28.6 KB)
Capture d’écran 2022-04-29 111834.jpg (355.7 KB)
Hey Aschdox,
I would try your scene but it is lacking some parts. Stash the geo and embed the custom hda you used.
Or better simplify the scene as much as possible so others can test it easily.
Cheers
CYTE
Edited by CYTE - May 3, 2022 11:36:54
@Aschdox I'm also experimenting with KineFX (Indie 19.0.589), I notice you talk about "rop_fbxanimoutput", in my attempts I end up using only the other node (character) for both static/tpose and animation cases. It may be my fault but I was having some issue with the "anim" node, kind of not following the "configureclipinfo".
As soon as I noticed the "character node" can be used for the animation part too, I went for it.
