Hello!!
Just wondering if anyone knows how to set the color space of the environment map I've loaded into an environment light node? I am using ACES with an OCIO system variable. And the environment map does not look correct, it's too dark.
Setting environment map color space
2694 4 1-
- midorisalt
- 10 posts
- jsmack
- 8177 posts
midorisalt
Hello!!
I think you'll have to convert it beforehand using composite nodes in houdini, ocioconvert or oiiotool, or some other software.
- midorisalt
- 10 posts
jsmackmidorisalt
Hello!!
Okay thank you that lead me in the right direction! I found more info in this thread: https://www.sidefx.com/forum/topic/61397/?page=1#post-273799 [www.sidefx.com]
Colors look correct now when comparing to reference... that's great but man that's complicated just for setting the color space of one image... :S
- jsmack
- 8177 posts
midorisalt
It's standard practice to transform all input colors to the working colorspace before consumption. The use of filename tokens to allow for automatic conversion is another option, except in the case of environment lights--it doesn't seem to be implemented here.
- midorisalt
- 10 posts
