Problem with Arnold for Houdini
   3079   0   0
Hi there
I have looked throughout this forum and on google for some help with this problem but I cant seem to find anything useful.
Basically I have Houdini 18.5 Education and Arnold for Houdini all installed ok.
I do get this log when I first open Houdini
 File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.696/houdini/python2.7libs\viewerstate\utils.py", line 977, in register_pystate_embedded
    template = node_type.hdaViewerStateModule().createViewerStateTemplate()
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.696/houdini/python2.7libs\hou.py", line 48192, in __getattr__
    return _hou.HDAViewerStateModule___getattr__(self, name)
AttributeError: 'module' object has no attribute 'createViewerStateTemplate'
Error running event handler:
  File "kinefx::Sop/reversefoot, ViewerStateModule", line 3, in <module>
ImportError: No module named kinefx
  File "kinefx::Sop/reversefoot, opdef:/kinefx::Sop/reversefoot?ViewerStateInstall", line 1, in <module>
  File "kinefx::Sop/rigdoctor, ViewerStateModule", line 12, in <module>
ImportError: No module named kinefx.ui
  File "kinefx::Sop/rigdoctor, opdef:/kinefx::Sop/rigdoctor?ViewerStateInstall", line 1, in <module>
  File "kinefx::Sop/rigmatchpose, ViewerStateModule", line 12, in <module>
ImportError: No module named kinefx__rig_pose
  File "kinefx::Sop/rigmatchpose, opdef:/kinefx::Sop/rigmatchpose?ViewerStateInstall", line 1, in <module>
  File "kinefx::Sop/rigmirrorpose, ViewerStateModule", line 14, in <module>
  File "kinefx::Sop/rigmirrorpose, opdef:/kinefx::Sop/rigmirrorpose?ViewerStateInstall", line 1, in <module>
  File "kinefx::Sop/scenecharacterimport, ViewerStateModule", line 11, in <module>
  File "kinefx::Sop/scenecharacterimport, opdef:/kinefx::Sop/scenecharacterimport?ViewerStateInstall", line 1, in <module>
  File "kinefx::Sop/skeletonmirror, ViewerStateModule", line 14, in <module>
  File "kinefx::Sop/skeletonmirror, opdef:/kinefx::Sop/skeletonmirror?ViewerStateInstall", line 1, in <module>
  File "kinefx::Sop/stabilizejoint, ViewerStateModule", line 3, in <module>
  File "kinefx::Sop/stabilizejoint, opdef:/kinefx::Sop/stabilizejoint?ViewerStateInstall", line 1, in <module>
00:00:00   656MB         | log started Fri Jul  1 13:03:48 2022
00:00:00   656MB         | Arnold 7.0.0.000:00:00   671MB         |  unloading 4 plugins
00:00:00   671MB         |   closing alembic_proc.dll ...
00:00:00   671MB         |   closing cryptomatte.dll ...
00:00:00   671MB         |   closing htoa_mandelbulb_proc.dll ...
00:00:00   671MB         |   closing usd_proc.dll ...
00:00:00   668MB         |  unloading plugins done
00:00:00   668MB         | Arnold shutdown
00:00:00   665MB         | log started Fri Jul  1 13:03:48 2022
00:00:00   665MB         | Arnold 7.0.0.0 [47ab20b9] windows clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/10/07 01:16:30
00:00:00   665MB         | running on W-B5312, pid=18388
00:00:00   665MB         |  1 x Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz (6 cores, 12 logical) with 16191MB
00:00:00   668MB         |  NVIDIA driver version 471.11 (Optix 60801)
00:00:00   668MB         |  GPU 0: NVIDIA GeForce GTX 1080 @ 1733MHz (compute 6.1) with 8192MB (879MB available) (NVLink:0)
00:00:00   668MB         |  Windows 10 (version 10.0, build 19042)
00:00:00   668MB         |  soft limit for open files is set at 2048
00:00:00   668MB         |
00:00:00   670MB         | [metadata] loading metadata file: C:\Program Files\Arnold to Houdini\scripts\bin\arnold.mtd
00:00:00   678MB         |  unloading 4 plugins
00:00:00   678MB         |   closing alembic_proc.dll ...
00:00:00   677MB         |   closing cryptomatte.dll ...
00:00:00   677MB         |   closing htoa_mandelbulb_proc.dll ...
00:00:00   677MB         |   closing usd_proc.dll ...
00:00:00   675MB         |  unloading plugins done
00:00:00   675MB         | Arnold shutdown
And later - if I try to render with Arnold at all.
Error
Failed to save output to file "Traceback (most recent call last):
File "C:/Program Files/Arnold to Houdini/soho/arnold.py", line 14, in <module>
HaSession.getSession().run()
File "C:/Program Files/Arnold to Houdini/scripts/python\htoa\session.py", line 519, in run
verbosity = log_levels[self.rop.sprop('ar_log_verbosity')]
KeyError: (None,)
Anyone have any idea?
Thanks in advance.
