How do we render with multiple cameras in Solaris?
I want to have multiple cameras with look-at targets, but I am not sure if having nulls as the look-at targets can be done in Solaris. I tried using scene import to import cameras into Solaris from the object level, but Karma does not recognize the switcher. Karma only recognizes the individual cameras.
I know this is pretty basic, but I'm just unaware of the workflow for rendering with multiple cameras.
Rendering with multiple cams in Solaris/Karma
2664 1 1-
- rubendionart
- 1 posts
- robp_sidefx
- 628 posts
Unfortunately, at present, Scene Import does not handle the Switcher node from /obj. There is an open request to add this support.
Can you elaborate a bit on what you're trying to achieve? Are you trying to render the same frame from two cameras (e.g., a stereo camera rig)? Are you trying to render a sequence where each shot uses a different camera? Something else?
