Just tried one, inelegantly. :/ it creates equiradius rounded corners, only suits for 2d cases.
working fine so far.
float dist = chf("dist"); int divisions = chi("Divisions");
int corners[] = expandpointgroup(0, chs("group"));
int PrimPts[] = primpoints(0, @primnum), PrimPts_new[]=PrimPts;
int primCorners[]; //intersection of current prim pts & selected pts group
foreach (int pt; PrimPts)
if (find(corners, pt) >= 0 && chs("group") != "")
append(primCorners, pt);
if(len(primCorners) > 0){
foreach(int i; primCorners){
vector corner = point(0, "P", i);
int p1 = neighbour(0, i, 0);
int p2 = neighbour(0, i, 1);
vector P1 = point(0, 'P', p1); //2 neighbouring Pts
vector P2 = point(0, 'P', p2);
vector dir1 = normalize(corner - P1); //2 tangents' dirs
vector dir2 = normalize(corner - P2);
vector normal = normalize(cross(dir1, dir2)); //normal of the plane
vector r1 = -normalize(cross(dir1, normal)); //2 radius dirs
vector r2 = normalize(cross(dir2, normal));
vector T1 = corner - dir1 * dist; //2 tangency Pts
vector T2 = corner - dir2 * dist;
vector C = T1 - r1 * length(cross(T2 - T1, r2)) / length(cross(r1, r2)); //centre of the circle
float radius = distance(C, T1);
vector x = r1; vector z = normal;
vector y = normalize(cross(z, x));
float angle = atan2(dot(r2, y), dot(r2, x)); //azimuth angle of r2
float stepAngle = angle / float(divisions);
int newPts[] = {};
for (int j = 0; j <= divisions; ++j) {
float jAngle = j * stepAngle; //Polar coord: set(jAngle, r, 0)
vector j_on_plane = set(cos(jAngle) * radius, sin(jAngle) * radius, 0); //Cartesian coord 2D
//maps 2D coord on the plane into world 3D coord
matrix M = ident();
M = set(
set(x.x, x.y, x.z),
set(y.x, y.y, y.z),
set(z.x, z.y, z.z)
vector j_in_3D = j_on_plane * M + C;
int newPt = addpoint(0, j_in_3D);
push(newPts, newPt);
int insert = find(PrimPts, i);
int insert_1 = find(PrimPts_new, i);
if(PrimPts[(insert+1) % len(PrimPts)] == p1) //match new pts' order
newPts = reverse(newPts);
removeindex(PrimPts_new, insert_1);
insert(PrimPts_new, insert_1, newPts);
removeprim(0, @primnum, 0);
foreach(int i; primCorners) removepoint(0, i);
addprim(0, "poly", PrimPts_new);
Fixed!
