How to convert HeightField to mesh by mask?
   5778   8   0
I have seen many cases where parts of the HeightField are transformed into mesh(for example: https://www.sidefx.com/forum/topic/68147/), but how is this done?
The Convert HeightField node does not support access mask and can only convert the entire HeightField to a mesh.
Edited by misakacirno - Aug. 19, 2022 04:33:10
You can use a HF Cutout by Object node (https://www.sidefx.com/docs/houdini/nodes/sop/heightfield_cutoutbyobject.html), which will convert the Height Field into a VDB, then convert it to polygons with a VDB convert node.
大卫·米奥齐
Thanks for your reply, but this way can only get regular areas, and I want to get some specific areas by Mask By Feature, this way doesn't seem to work.
Mask layers get converted into point attributes, so you can use some vex...
You could just convert your entire heightfield to a mesh and delete the parts you dont want.
heightfield_cutout.hipnc (198.9 KB)
misakacirno
大卫·米奥齐
The channel used for cutout is Alpha, although getting houdini to understand that the layer called 'alpha' is for cutout is another problem entirely.
DavideMiozzi
This is very enlightening for me, thank you very much!
gorrod
Very detailed answer, I think this should be what I want!
jsmack
misakacirno
大卫·米奥齐
I've made a few attempts, but haven't managed to use mask as alpha.
