Houdini Packages, Subprocess, and duplicate env vars
   3058   5   1
I have an issue and I'm curious if any of you have any solutions. I've set some environment variables via a package located in a custom directory set via HOUDINI_PACAGE_DIR. When I run Houdini the variable load find and there are no issues. However, for purposes of publishing on a pipeline, I am using subprocess within a python script to copy, open, and execute some rops within a hip files. The strange thing is, the values of the env vars I've set within that package are doubled or a copy of that values is appended. MYENV1 would normally have a values of "C:/Users/me/some/path". When accessed from within a Houdini hip file opened via subprocess it has a value of "C:/Users/me/some/path;C:/Users/me/some/path". Additionally, this behavior does not happen if I set the environment variables via houdini.env.
I'm not sure how to prevent this from happening. Any thoughts?
Here's the simple package json I was using:
    "enable": false,
    "env": [
            "MYENV1": [
                    "houdini_os == 'windows'": "C:/Users/me/some/path"
                    "houdini_os == 'macos'": "/Users/me/some/path"
            "MYENV2": [
                    "houdini_os == 'windows'": "C:/Users/me/some/other/path"
                    "houdini_os == 'macos'": "/Users/me/some/other/path"
It theoretically makes sense, if you are spawning a subprocess in an environment that already has that variable, packages prepend paths by default so you may end up with duplicate path
Maybe try using
"method" : "replace"
Or there is also
"load_package_once" : true
Which I don't know if would work for nested calls but worth a try
It's strange. I've tried setting both of these in my package and I'm still getting a double loading of the environment variables.
plobnop
"method" is per variable setting, make sure it's specified in correct places in your json according to https://www.sidefx.com/docs/houdini/ref/plugins.html [www.sidefx.com]
but again there may also be other causes for your issue
Thanks for the link tamte. I've been using the info on that page for all along. I'm beginning to wonder if this is a bug. If I remove the houdini_os expression I no longer get a duplication of my env var values. Either this is a bug or I'm still not getting the syntax correct in my package.
WORKS (does not duplicate var value):
    "enable": true,
    "load_package_once": true,
    "env": [
            "var": "MYENVVAR1",
            "value": "C:/Users/me/some/path",
            "method": "replace"
            "var": "MYENVVAR2",
            "value": "C:/Users/me/some/other/path",
            "method": "replace"
os.environ result:
MYENVVAR1:C:/Users/me/some/path
MYENVVAR2:C:/Users/me/some/other/path
Does NOT work (duplicates var value):
    "enable": true,
    "env": [
            "var": "MYENVVAR1",
            "value": [
                    "houdini_os == 'windows'": "C:/Users/me/some/path",
                    "method": "replace"
            "var": "MYENVVAR2",
            "value": [
                    "houdini_os == 'windows'": "C:/Users/me/some/other/path",
                    "method": "replace"
os.environ result:
MYENVVAR1:C:/Users/me/some/path;C:/Users/me/some/path
MYENVVAR2:C:/Users/me/some/other/path;C:/Users/me/some/other/path
Try setting HOUDINI_PACKAGE_SKIP=1 before launching your process, this will disable the package processing and will prevent the subprocess to duplicate the env vars.
