PDG ImageMagick MipMapping
   2618   4   2
Hi.
I have a really simple TOP network. I am trying to use ImageMagick to convert to EXR while also saving out the EXR's as mipmap. Going by the online help I think I am typing the command correctly but it does not seem to mipmap. Has anyone else had any luck with this?
Best. Mark
Edited by Mark Wallman - Aug. 29, 2022 11:57:18
imageMagick_MipMap.hipnc (99.9 KB)
Have you tested command line Magick at all? I usually set up everything command line (the order of things sometimes matters for conversions, for example) then translate it into PDG once I have it fully working. Then you can see what PDG is executing in the Python code it outputs, making debugging easier IMO.
Peter B
Peter Bowmar
____________
H8. Thanks, I'll go from the command line, and build up. Best
I'm guessing why you get error is that ImageMagick Binary Path is not set correctly, maybe?
(check the Custom ImageMagik...then set the ImageMagick.exe)
Here's something I set for combining nth images into one picture, using ImageMagick PDG node(in Houdini 18 though).
Maybe you might find useful. Cheers,
Hi. That screegrab is really helpful. Thanks! Mark
