I found endSave call is removed in H19.5. Any plan to add it back or is there an alternative method to use?
A simple usage is, we are collecting information during Houdini saving out usd files and generate a log.
endSave in outputprocessor
2130 2 1-
- wayne lai
- 3 posts
- mtucker
- 4583 posts
In 19.5 a new instance of your output processor object is created for each save operation, and destroyed at the end of the save. This (we thought) made the endSave call unnecessary. But I suppose the lack of proper dewstructor methods in Python means there are still use cases for this method (or something equivalent)? Please submit an RFE to request the re-introduction of this method if you need it (though an alternative approach in your case might be to write the log as you go, and rely on the destruction of the output processor object to destroy/close the log file object). Thanks!
- wayne lai
- 3 posts
