Vellum cloth
   1284   2   0
Hello, how to keep the shapes more rigid, less deforming, I am simulating leaves on the ground and when the sim starts, they are becoming super flat. I increased stiffness but is is not doing something looking like leave, dry leave are not so soft..
Can you give me some feedback?
Thank you!
Sebastien Levieux
- which stiffness? make sure you are increasing Bend Stiffness
- also make sure your leaf geo is not super dense, if it is, consider simming lower res, the lower the res the easier to keep the shape
- if necessary increase substeps or at least constraint iterations
Edited by tamte - Oct. 6, 2022 18:27:00
tamte
Sebastien Levieux
Hi, thank you for your help, finaly I beleived I have to setup both stiffness at 0!!!
tamte
Sebastien Levieux
Do you think it is a enought like that?
