About VEX Noise direction offset problem.
   2592   4   1
I implemented the noise according to the method of VEX Noise [www.sidefx.com], but the final result is that the whole is offset in the +x, +y direction. Is there a way to offset this offset?
Thanks for your help!
VEX Code
vector freq = chv("freq");
vector off = chv("freq_off");
vector amp = @Cd.r;
float rough = chf("rough");
float atten = 1;
float turbulence = chf("turb");
float mult_height = chf("mult_height");
vector active_v = anoise(v@P * freq + off, turbulence, rough, atten) * amp * mult_height;
v@P += active_v;
v@Cd = fit01(active_v.y, 0, 1);
f@pscale = 0.01;
v@Cd = chramp("color", active_v.y);
Edited by HenDaSheng - Oct. 13, 2022 04:55:45
You are offsetting it in your parameters right? I don't get what behavior is wrong exactly? What are you trying to achieve?
Technical VFX artist @ Housemarque / Sony Interactive Entertainment
罗伯特
Thank you for your reply, I hope it can be offset in the four directions of x, -x, y, -y, and now it only offsets in two directions of x, y (as shown in the picture).
The bounds of alligator noise is 0-1, so you need to remap it if you want it zero centered:
vector active_v = anoise(v@P * freq + off, turbulence, rough, atten);
active_v = fit ( active_v, 0, 0.7, -1, 1 ); // You can play with 0.7 to center the values based on your geometry.
active_v = active_v * amp * mult_height;
animatrix_
Thanks for your help, this is my attempt, adding the mapping of color and pscale on the basis of noise, friends who encounter similar problems can refer to.
vector amp = @Cd.r;
float atten = 1;
vector mult_height = chv("mult_height");
active_v = fit(active_v, 0, 0.7, -1, 1) * amp * mult_height;
v@P += active_v;
v@P.y += mult_height.y;
v@Cd = fit01(v@P.y, 0, 1);
@pscale = chramp("scale", @Cd.r) * chf("scale_mult") * 0.03;
v@Cd = chramp("color",v@P.y);
