Refine a polyline with 3 points
3168 7 0-
- element33
- 94 posts
I want to add a point to a line at a location closest to a point A (just outside the line). If the line has only 2 points (start,end), I can use the "xyzdist" expression to find the uv on the line closest to point A, and use Refine SOP to add a point. It works. But if the line has 3 points (start, end, and a point somewhere in the middle), the uv reported by "xyzdist" and passed on to Refine looks wrong, it's not where it used to be. I suspect it's an issue with parametric uv's with more than 2 points on a line. I tried to re-order the 3 points on the 3-point line, but it doesn't make any difference. I can use the Convert-Line SOP to fix this, i.e. convert the 3-point line to 2 separate lines: the "xyzdist" expression works again. Can this be done without the Convert-Line SOP?
Edited by element33 - Nov. 23, 2022 00:17:29
- animatrix_
- 5125 posts
What you can do is to create a normalized float attribute before changing topology, and then find the closest point on the line using your point, and create this point in VEX.
Then comparing the value of the above float attribute of the old points and the new one, insert the new point into the array of old points using the primpoints function.
After this, delete the current primitive and recreate it using the new point list.
If you want to interpolate point, vertex, primitive attributes for all types, and preserve point, vertex, edge and primitive groups, you have to do a lot more work of course.
I would recommend creating tracking attributes and using Attribute Interpolate SOP to do the heavy lifting. But each one have to be handled differently. Doing all of this in VEX would be a ton of code and unimaginably slow.
- CYTE
- 803 posts
- element33
- 94 posts
- element33
- 94 posts
I found a one-SOP method that keeps the attribs. On the 3 point line, it turns out the uv coord reported by "xyzdist" is for the nearest segment of the 3-point line (the shorter part of the 3-pt line in the pic above). Instead of Refine, I can use a PolySplit, with the split location defined as p(a)-(b): (r) where (a) and (b) are point numbers defining the shorter segment, and (r) is the uv reported by "xyzdist".
Edited by element33 - Nov. 23, 2022 08:55:11
- CYTE
- 803 posts
- element33
- 94 posts
Screenshot OK? I load a bunch of dependencies by default, I'd have to clean up the hip. It's just one "xyzdist" expression. My case is 2D (no "Z"). Also, I already know the IDs of the closest points on the line. To generalize, you'd need to ID them first.
Edited by element33 - Nov. 23, 2022 12:13:15
- willh
- 134 posts
