Hi!
I've spent most of today trying to fix this and haven't found any solutions yet. I have a USD Solaris scene set up that I'm trying to render using Redshift. It's a multiple AOV scene with a bunch of passes (diffuse, gi, etc).
Everything renders great in the viewport, I can select the different passes and see the results. Anytime I try to render using the Render USD Scene ROP, be it MPlay, Save to Disk or Save to Disk in Background, my scene doesn't render. Using the last two options doesn't create any files even though it says that the rendering is finished, and rendering to MPlay lasts about 30 seconds and produces black images (besides emission pass, which ends up grey for some reason). I've tried rendering without AOVs, but that doesn't fix the issue.
Appreciate any help!
Edit: Tried rendering in Karma, getting the same result, nothing gets rendered. So it's definitely not Redshift's fault
Solaris renders in Viewport but doesn't in ROP
5471 8 2-
- dravec_ky
- 13 posts
- robp_sidefx
- 597 posts
- dravec_ky
- 13 posts
- TysonG
- 1 posts
dravec_kyrobp_sidefxHi! Incredibly sorry for the late reply, It ended up being the USDs which the renderers read from not being properly set up due to some Solaris USD export options.
Happy New Year! Do you have a hip file you can share?
Hey, would you be able to be a little more specific? Started to play around with Karma and am running into a similar issue. Viewport renders are fine but the USD Render ROP is outputting black.
- AhmedHindy
- 146 posts
- NicTanghe
- 244 posts
- robp_sidefx
- 597 posts
- shaw021
- 3 posts
- AhmedHindy
- 146 posts
