I have a SOP subnet that contains a free-standing null that hosts many channel linked parameters (floats, vectors, ordered menus, ramps...) as a controller for nodes within the subnet.
I'd now like to make that subnet a HDA.
Is there any way to 'promote' the controller null parameters to HDA level in one move, or will I need to rebuild the entire parameter interface one control at a time?
Once you've done that, how can you remove the controller node from the chain of dependencies/references? In other words, I would like to delete the controller node so that the parameters reference the HDA directly.
