List of media/external files used in a Hip scene?
   2001   3   2
Is there way to see a list of all the referenced external media used in a scene so the scene can be migrated to another project with all the relevant files it needs?
i.e. Where the hip expects to find
- Images
- Audio
- external cached files etc.
We all sometimes want to repurpose an old scene, but not have to duplicate the entire project contents that the scene was in.
At the moment you have to go into each node (e.g. texture nodes) to check which textures are needed before copying them into the new project.
It would be great if there's a single list to show all files that are needed in a scene.
Even better to have a Migrate Hip with content script of course, if one's been created.
Many thanks,
Adam
(Softimage refugee who's missing the External Files page)
there is Render/Pre-Flight Scene which may be helpful to get overview of external files
or for archiving you may want to have a look at Labs Archive Project TOP
potentially also https://www.sidefx.com/docs/houdini/hom/hou/fileReferences.html [www.sidefx.com] if you want to get them through python, however I dont know how complete those lists are
Edited by tamte - Jan. 28, 2023 13:29:20
Hi Tomas,
Thanks for that.
I did find a thread that highlighted the Pre-Flight Scene run a little earlier on as well.
Will definitely check out the Labs option as well though.
I'll stick a "Migrate HIP to New Project (with assets)" onto the request pile.
Adam.
If this is not solved, could you please provide a "dummy" file containing all the node types you would like to pick file references from? Please try to mimic the typical network you would use. The actual files are not needed.
