Houdini 19.5.493 / Ubuntu 22.04.1 LTS - Crash on exit.
   4063   6   1
I guess the best time for a crash is when you are exiting the program, so it's not a show stopper but it does indicate that there is something wrong and I'm trying to get the most stable work environment possible.
Whenever I close the Houdini window by clicking on the top right window (X) button or File>Quit I get a pop up asking me to send a crash log to side effects software. This is the log:
Crash report from user; Houdini FX Version 19.5.493
Uptime 21756 seconds
Fri Feb 17 23:38:24 2023
Caught signal 6
Traceback from 149194 ThreadId=0x7f283f5d6e80
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so>
__sigaction <libc.so.6>
pthread_kill <libc.so.6>
raise <libc.so.6>
abort <libc.so.6>
__fsetlocking <libc.so.6>
timer_settime <libc.so.6>
__default_morecore <libc.so.6>
free <libc.so.6>
free <libai.so>
AiFree <libai.so>
_init <libai.so>
putenv <libc.so.6>
exit <libc.so.6>
UT_Exit::doExit(int, bool) <libHoudiniUT.so>
UT_Exit::exitWithSpecificCode(int) <libHoudiniUT.so>
main <libHoudiniUI.so>
__libc_init_first <libc.so.6>
__libc_start_main <libc.so.6>
main <houdini-bin>
I also get a similar message whenever a render completes, I'm rendering with arnold:
free(): invalid pointer
163767: (sent by pid 163767)
-- TRACEBACK BEGIN --
Traceback from karma 19.5.493 (Compiled on linux-x86_64-gcc9.3):
stackTrace(UTsignalHandlerArg) <libHoudiniUT.so>
raise <libc.so.6>
abort <libc.so.6>
free <libc.so.6>
free <libai.so>
AiFree <libai.so>
_init <libai.so>
putenv <libc.so.6>
exit <libc.so.6>
UT_Exit::exit(UT_Exit::UT_ExitCode) <libHoudiniUT.so>
std::runtime_error::what() const <husk>
-- TRACEBACK END --
When I do not have arnold loaded it only sometimes crashes on exit with this output on the command line:
166630: Fatal error: Segmentation fault (sent by pid 10092)
Any thoughts?
unfortunately in ubuntu 22.04.1 itself houdini trying to crash suddenly
i think this issue related on ubuntu itself
but , i tried houdini in ubuntu based distros like kde neon , pop os , elementary os ,working good , but not working good on ubuntu itself
currently i'm using houdini in fedora 37 working nicely
Edited by SMC7192 - Feb. 19, 2023 00:22:47
It looks like the crash may be in libai, which is part of Arnold. I would recommend that you reach out to their support team and see if they have any ideas.
johnmather
Still crashes without arnold loaded.
I take it back, I thought I tried loading without Arnold and it crashed, I was pretty sure it crashed. But now it's fine without Arnold loaded. So I guess this one is related to the libai.
davidostler
Did you managed to fix it ?
Keep your folder /home/user/houdini19.5.Bak,Relaunch again,if stil crash,Something else or maybe version houdini.
The most crash in linux,A cause graphic card,Try update driver Or try download package exactly version,After Install manually .
