VEX find closest float value to target?
   2373   5   0
My knowledge of VEX is fairly newborn. So I'm having a hard time figuring out how I can achieve my goal here.
in my vex script, I have a series of float values. These values change depending on the geometry. for the sake of simplicity, let's say this is what I have:
float a=11.5;
float b-23;
float c=48.9;
float d=90.2;
float target=45;
What could I write here to look through those float values and automatically pick whichever one is closest to the target?
Thoughts and ideas are very much appreciated. Thanks!
Edited by Poliigon - Feb. 21, 2023 14:12:21
Hi Poliigon,
you could iterate over an array and store the index and update the minimal absolute difference to the target value.
float vals[] = array(12.3, 34.1, 54.7, 67.9);
float target = 40.0;
float d_min = 10000.0;
int index = -1;
foreach(int i; float val; vals){
    float d = abs(val - target);
    if(d < d_min){
        d_min = d;
        index = i;
f@closest_value = vals[index];
Alternatively you just set the float values as positions of a point cloud and use the nearpoint()-function.
Konstantin Magnus
Hi Poliigon,
int index = -1;
    if(d < d_min){
        d_min = d;
        index = i;
Thanks a lot!
I'm very curious about the point cloud idea, as I had thought of that as well. Though I am unsure how to set the position of points based on those float values. If you have a minute, would you mind breaking that down?
You would overwrite the position:
v@P = set(f@val, 0.0, 0.0);
and search for the closest match:
float target = chf('target');
vector pos = set(target, 0, 0);
int pt_near = nearpoint(0, pos);
i@group_target = pt_near == i@ptnum;
target_val.hipnc (129.6 KB)
Konstantin Magnus
You're a legend. Thanks mate!
If you have so many values in a sorted state i.e. in the millions or billions, you can also use binary search to speed up the search exponentially:
https://en.wikipedia.org/wiki/Binary_search_algorithm [en.wikipedia.org]
However Konstantin's methods are already very established for practically any case.
