How to scan for cook errors after a hou.ui.triggerUpdate()
   2564   1   0
I have a setup where I can cook specic nodes, via python, using displayflags and hou.ui.triggerUpdate().
Now one of the sub node has python error (function X not defined) so the cook stops right there.
How can I get the error of that node, in my script after the call to hou.ui.triggerUpdate() ?
I do this to scan ALL nodes for error, but they all report nothing, even tough I see one of them with a python error (red triangle) :
def CheckForErrors(node):
    def PrintResult(node):
        if len(node.errors()) != 0 or len(node.warnings()) != 0 or len(node.messages()) != 0:
            print("State %-34s t=%-40s e=%s w=%s m=%s"%(str(node), node.type().nameWithCategory(), str(node.errors()), str(node.warnings()),str(node.messages())  ))
    PrintResult(node)
    for n in node.children():
        CheckForErrors(n)
        PrintResult(n)
cook_done = asyncio.Event()
cook_done_lambda = lambda: cook_done.set()
hou.ui.addTriggerUpdateCallback(cook_done_lambda)
await cook_done.wait()
hou.ui.removeTriggerUpdateCallback(cook_done_lambda)
CheckForErrors(hou.node("/"))
#CheckForErrors reports nothing even tough one node is in error state after the cook.
Tnx
Edited by fveilleux - Feb. 24, 2023 10:47:32
I found the problem.
Houdini was actually not done when I traversed the network.
using executeDeferred made it properly detect/show erros.
hdefereval.executeDeferred(CheckForErrors, hou.node("/"))
