Set custom render frame range for mantra?
   1215   1   0
In the mantra node, for Start/End/Inc there is an expression set for the full timeline presumably. Are you supposed to delete the expression if you want to enter your own frame range?
Also, am I right that if you set Inc to 2 it will render e=very second frame?
Both correct.
