How to create an empty Transform at given local position?
   1721   1   1
Hi! Is there any way to create an empty transform from a specific point, such as a centroid? I have discovered a method to generate separate meshes in Unity using Merge Packed, but I'm unsure how to create an empty transform in my Unity HDA. I want to use this empty transform as a root for positioning future objects.
I attempted to create a centroid and export it, but it did not generate anything.
Edited by DrViJ - March 2, 2023 01:45:47
Looks like I should try fbx instead of engine, cause FBX baker has a feature to create hierarchy from paths, which is not available from houdini engine for unity, and which gives a better way to give names to objects with attributes
Edited by DrViJ - March 2, 2023 16:21:07
