Blast Node won't evaluate ad hoc Group driven by channel
   697   0   1
I'm trying to get Blast to recognize a primitive group driven by a channel, e.g.
@bldgID==ch('soloBldgID')
where the channel is either a custom integer channel created in the Blast node itself , OR a reference to data from a different node, eg
@bldgID==point("../REF_ptnum/","ptnum",0)
where REF_ptnum is just a null nested within a For Each Pt loop running on some scattered points.
If I type in an explicit value, Blast responds as expected, but channels don't seem to evaluate, returning just 0.
Am I doing something wrong, or is there some limitation of the Blast node? Delete node is giving me same results.
Ultimately I'm trying to Copy to Points a variety of objects (read from a sequence of bgeo's) without having to separate out a bunch of objects manually into a Switch. Hope this makes sense. My file is from a paid tutorial unfortunately, but I made a dumbed down version fore reference here.
THANKS!!!
CantBlastGroupExpWChannelRef.hiplc (448.2 KB)
