Constrained collision objects
   1211   0   1
Hi all,
I've noticed an object that gets it animation from a constraint (path in this case) affects flip much more than a simple object level animation doing the same move.
I'm assuming the object and sop level animations are correct as they match, and the constrained one is wrong. I know constraints are a bit different in H, should I steer clear of using them in cases like this?
cheers,
A
EDIT:
I've actually got this the wrong way round... The sop level animation is the odd one.
Edited by Andi Farhall - April 18, 2023 11:30:55
collisionDifferences.hiplc (2.7 MB)
